TractorLinks.com
Show Parts for Model:
Re: Tips for removing John Deere 60 manifold?
machineryman
05-19-2017 19:44:01
yes it will air cut the head with extended use. I've removed several of these. The intake bolts will probably unscrew however the exhaust bolts will be frozen in the exhaust manifold. If you removed the gas tank you can use an impact wrench...use a size that you will need to drive onto the bolt....impact back and forth and you may get them to back out. I've also broken the cast iron from around the bolts to all allow the bolt to spin. Use a sharp chisel to break it up and down along the bolt but don't break it where it will fall into the head. You can use penetrating oil around the crack. be sure to wear goggles. Would be easier for me to do than explain.
