2955 leaking hydraulic remotes.
cowman79
My tractor is leaking hydraulic fluid from the drains on the couplers when there is noting connected. Are there replacement parts for the couplers that will keep this from leaking or are my poppet valves leaking by. Not sure if this is a common problem. Also are these units supposed to have drains to route the fluid to the bottom of the tractor.
Breakaway couplers were offered with 2 different styles of leak off lines. One style simply let oil leak on ground & other style returned oil to LH side of rockshaft housing.
Seals are available to stop breakaway coupler from leaking if properly installed. It's possible poppet valves need attention depending on how bad oil leak is.
(quoted from post at 08:58:52 05/17/17)
I gave replaced these lines already the ones I am talking about are the one that connect to the front dust cover.
