johndeeregreg
my 720 is leaking hydraulic oil from the cap nut and screw that is used to switch between single and double acting cylinders when the pump is engaged. i have only been using the 3 point a little bit this spring, no scv use yet, i put a new sealing washer under the cap nut but it still leaks and its tight enough that i don't want to go any tighter. it is set for a double action cylinder but that shouldn't make any difference.
what is making it leak or better yet what do i have to do to get it to quit? should i try another washer and make sure there the sealing areas are clean and flat?
