Hotflashjr
- Location
- Western MA
Looked at a 3055 recently to add to the fleet. MFWD, Partial Power Shift, Hi/Lo, 2 sets of remotes. Front tires aren't the best but the rears are good. Tractor ran good, shifted good. Hooked up a few implements and ran them with no issues and hydraulics worked with no hesitation. One issue spotted was the front driveshaft had a wobble. The stub shaft coming out of the drop box was solid, no leaks, no movement but the actual u-joint on the driveshaft and the end itself seemed to be the trouble. Working tach had just under 5k hours.
Anything to look out for on these. I realize these were made for the European market and that could down the road make parts become a bit more pricey possibly. Taken that into consideration.
