John Deere 2010 hydraulic problems
Just bought a 2010 last night checked it. everything worked went to use it today 3 pt would not lower so i put weight on it. It lowered but now wont go up and i have no power steering and no remote hydrualics. Any help appreciated Sod Buster.
There should be a spring that is used to lower the hydraulics. I have a 1010 w/ similar hydraulics w/out the spring and I can push them down by hand. Have you checked the hydraulic fluid level?
Did you have power steering before? Sounds like a pump issue.
The 2010 have a fine mesh screen filter in the hydraulic sump. Mine lost power steering for a few years before I simply pulled the screen,
flushed it off very well. Duh. Works great now.
