Bvillerwhde
New User
Ok so i have a serious oil leak from the transmission into the bellhousing clutch are. Looks as the leak is from around the outer input shaft that goes from the clutch into the transmission. There are two input shafts into the transmission the smaller one goes through the larger i assume one is transmission the other is pto. Heres the question, i removed the two freeze plugs but cant figure out how to remove the shaft that supports the pto throw out bearing forks and second question is do i remove the shafts by removing the 4 bolts from behind the throw out bearings or do i have to split the tractor again at the next section back to access seals from the back?
