ID part no. AA204R what tractor used on
HILL
I have several of these parts that came from a closed JD dealership and I have looked in all of my stuff and can not find anything. It is gast tank valve with a screen on the end with 1/4 pipe threads on one end, the other outlet has a compression fitting and it has 1/4 turn petcock on it.
According to the JD parts manual, those are called Valve, fuel shut-off needle, and only used on the earliest model A tractors, but didn't search to see other models like the B, D, etc., which are very likely the same. You can look this up on "JDparts.deere.com"
Looking at the parts book, it shows that this part was used on the 1934 A Tractors, serial number 410000 thru 410850.
