John Deere M hydrualics
oldcows
My John Deere M will not lift my KBL disk. It will raise the drawbar fine with no load. There are no visible leaks and the oil level is good. I have the service manuals for this tractor and will start testing as directed. I'm wondering if it may be bypassing internally. Any comments and experiences?
Thanks
Mark
(quoted from post at 15:05:12 05/08/17) My John Deere M will not lift my KBL disk. It will raise the drawbar fine with no load. There are no visible leaks and the oil level is good. I have the service manuals for this tractor and will start testing as directed. I'm wondering if it may be bypassing internally. Any comments and experiences?
Thanks
Mark
Years ago I had the same issue and the "head", item #20 was cracked allowing oil to blow by the piston.
With the lift raised up (no implement attached) can you push the lift back down? Oil is by-passing some where internally.
I would park it uphill and drain the old oil out and refill it with 30wt NON detergent motor oil. You would be suprised how much better a tired lift works with that inside.
