60 rockshaft again and again and again
Ok I have been into my 60's rockshaft housing about 3 times in the last 2 years or so. Symptoms are this: I have a 45 loader plumbed out the side of the power troll housing. It allows me to lift the loader, when I do this the rockshaft goes up and then comes down. I have a valve in the pressure side of the loader arms so when I want to just use the rockshaft point, I lift the loader, close the valve and the loader stays put and I use the rockshaft/3 point hitch happily cutting hay etc. But what seems to happen over time, as I use the rockshaft/three point, it stops lifting and wont hold anything up. I first tried replacing the o-ring and leather in the piston from the back of the tractor. I did this 3 or so times. It works for a while, then the same thing happens. I had a heavy box blade on it last time and it lasted a day, then it wouldn't lift nothing. I did have a problem with the loader drifting down, and I finally got a replacement spring in the power troll and it solved the loader drifting down problem, but not the 3 point problem. Next I took the rockshaft housing off again and this time replaced the gasket between the rockshaft cylinder and the rockshaft housing. The pressure port was blown out allowing fluid to leak past the pressure side into the cylinder causing the piston to not push out making the rockshaft go up. At last I thought I found my smoking bullet with all my problems. I replaced the gasket with a new one about a month ago and it worked. Parked it in the barn. Today I went out and used the loader to push some junk out of the way and now the rockshaft is not hardly functioning again. I hate to go back in the rockshaft again, but I don't know what to look for now. I have backed out the throttling valve till its closed to see if the rockshaft would hold up and it wont, so now it sounds like its the cylinder and piston again. See pictures of what I have found over the years of tearing this down. I don't know if I should try another cylinder and piston combo or what? I am using universal hydraulic fluid.
Ok,so before the I don't know anything crowd rolls in here we go_Order 2_gaskets then get a piece of copper sheet and trace the outline of gasket on the copper. Cut out the copper to the tracing,sandwhich copper between the 2 gaskets use head gasket sgelac,install new cup or o-ring on piston reinstall.I was told this repair by old JD mechanic
Take the cylinder barrel to a hydraulic repair shop or machine shop and have a recess machined out for an o-ring around the pressure port and throw away the gasket.
So as my suggestion last time. Have you ever checked your pressure relief valve setting ? If that gasket blowed again you are going to have to test the pressure with a set of hyd. couplings that plug into the back. This will bypass the rockshaft cyl.
Yes that was my next try? Does it have to be plumbed into the back fittings or can I use the side fittings to test the pressure? I have pioneer fittings plumbed into the side and that would make it pretty easy to test?
If that gasket is blowed then trying it at the side fittings will still let oil get to the rockshaft. Putting the hyd. cyl. tips that go into the back will bypass the rockshaft cyl. Someone could have that pressure shimmed way up if you are having this much trouble with it.
You need to plumb the loader into the back of the valve when you run the way you are you get way over psi on the rock shaft piston as you push forward with the bucket
