JD 8300 Shuts down and wont run
George 3
A friend's JD 8300 shut down without warning in the field. Would not start afterwards. Came back the next day and managed to get it going long enough to get it into their drive shed. Then tried to restart several times and no luck. Starter will turn over but will not fire up. Does anyone have any ideas of what could cause this to happen? Diagnosis can get expensive if you don't know where to start to look.
I'm thinking you need a scan tool for that. Any heavy
truck code reader will do. That will send you in
general direction. Before anything else change fuel
and air filter.
