2840 high pressure leak
fordfx413
2840 has a high pressure leak I believe. When running the tractor the inner scv gets warm. When I move the flow valve with the scv lever in neutral you can hear the pump start working harder. Also the rock shaft lever in a certain position will start squealing too. I removed the hyd fill cap and about had oil shooting out of the fill. Can these to be related or am I looking at 2 leaks? I have rebuilt a scv before but not rockshaft valve. What does the rockshaft valve consist of? Thank you
OOPS I forgot to click on continue to upload photo.
