hillbilly2
Picked up a 68 3020D recently. Currently will run about 30 seconds then cut off. Runs less every time you try this until it sits for awhile.
From my research it sounds like this could be the plastic flex ring for the governor in the pump. Stanadyne DB pump with date of 1997 on it.
Where do you get a service manual for pump? It looks like parts can be bought for about $50 of its $800 to exchange with a reman.
Is this something someone with basic mechanical knowledge could do or does it need sent to a shop?
Thanks
Thanks
