Runningranch
New User
Hi all,
I just found this site, and love it! I just aquired a 55 acre parcel next to our 80. I needed a tractor and a buddy had a jd 2510 that he said had coolant in the oil that I could have for cheap if I wanted to fix it. He said he had a guy look at it and the guy said it was a head gasket. Question is when I get the head off, will it be obvious that the problem is the head gasket and is there anything else I should check on while I have the head off? The tractor has new tires and the pant looks good. There are no leaks of any kind so I think it could be a good tractor if I can get it going. I only have 12 acres of open ground to work, so I think this tractor should work fine for what I need.
Thanks for reading!
Chris
Thanks for reading!
Chris
