1020 three point
Just purchased a 1020 Orchard model that runs super with no problems other than the three point is extremely slow and is full of hydraulic oil.
What should I be looking for as a problem?
I would suggest to change hyd filter & check/clean sump screen(key 15). Checking screen requires draining hyd oil unless one inserts the nozzle of an operating shop vac in hyd filler hole to create a vacuum. While servicing check to be sure hyd filter relief valve(keys 7-9) isn't stuck in trans case.
AR75603 Filter Element - ADD 8.31 USD
