I've got a 2350 ( cab ) that after running 10-15 minutes the
hyd get real slow while idling and only have about 700-800 psi idling but
can run it up 1200-1300 rpm and it works fine and has 2300-
2400 psi steady. When you first start it everything is good
idling until it warms up alittle. It won't get any worse idling (
around 700-800 ) all day long or will the pressure drop when
you have the rpms up. I put a new hyd pump on thinking it
may be wore out but does the same thing. Cleaned the intake
filter changed hyd filter. Any idea where to start or look?
