Hello,
I'm in the process of trying to get the cam out of a 46 A and am kinda stuck. I've been following the IT manual and it's not very specific but I have the timing gear cover and flywheel off and have also removed the left side cam bearing. I know the governer has to come off to pull the cam gear out from the top. Does the entire fan shaft have to come out with it or can I disconnect it from the box first? Also I've read the lifter block has to be loosened, how do I go about that? Does the oil pump need to be removed entirely? I've never worked on one of these machines before so any help is very appreciated. Thanks
