4250 New Steps Right/Left
2510Paul
I put the new style steps on the left side of my 4250. They work a lot better for me to get in and out of the tractor. I took the old steps and put them on the right side of my 4250 so I could get up and wash the right windshield. There was not a hole in the frame to accommodate the step so I added my own place to fasten the step under the frame. I was not about to add holes to the frame, a structural member. I also added my own plate under the battery box to accommodate all of this. The other benefit is the steps are slightly further away from the tractor to make more room for me. The valve cover makes a good hand hold to pull myself up on the steps when the valve cover is not overly hot.
Note I also put a K&M tool box and step on the left side so I could get to the fuel cap and peer in. I found two of these RED tool boxes at an auction. A friend sandblasted and painted them green for me. These are great tool boxes. If you look close you will see the adapter plate I made to put the tool box on a JD.
See Pictures.
Paul
That looks nice. I've thought about putting those steps on my 4430. Never considered using the old steps on the other side. I like the toolbox as well. A while back I was fueling mine up and made the reach from the steps to the front axle and my foot slipped off. Landed on the axle hitting my ribs. Luckily it was winter and had heavy coat on. Might have had broken ribs instead of badly bruised.
Ouch!
Yes, the handle on the new steps is close enough to the tractor in the position I have it that I can easily get up on the new step and then step around the handle to the toolbox and to the front axle if I need to. I am 6'4" and 300# and the tool box handles me just fine. I am still considering putting a "grippy" step on the front axle so as to not slip.
Thanks for you comments.
Paul
