I got the LED Amber Warning Lights on my 4250 and operating. See my earlier posts. When either just on or ALL flashing they work absolutely great. Flashing is about 50% duty cycle.
When using as a blinker the Right Turn puts the lights in a 10-20% duty cycle, very bright, and the Left Turn side does not work at all. As I have said before, my son tells me the cab connector at the lower right side of the console just in front of the breaks or behind the RH battery is problematic. I see mine is covered in oil. See Picture.
I need to study the schematics too see why when working as four warning lights they work perfectly and why as Right and Left Blinkers I am getting mixed results. I hope that will give me some clues.
Looking at the rear of the tractor the rear flood lights were replaced and some wiring repaired although what I did does not explain whey they are working perfectly now. Again, I suspect that connector.
And of course comments/suggestions are welcome. After plowing I will power wash everything and dig into it.
See Pictures.
Paul
See Pictures.
Paul
