Ignition switch 620 John Deere
Spshamel
New User
Need a little advice. Need to change ignition switch but hour meter cable is so short I can't get plate off enough to work on it.
Yes a pair of pliers will loosen it up just fine, should just thread off with fingers after that. Just align cable as it goes back in to finish.
You will also need to disconnect the oil gauge pressure line at the sediment bowel to be able to move the instrument panel.
If you think forcing the Tach cable housing may damage it, take the Tach loose and there will be no pressure on it..
They are pretty stiff, when installing a new one...
