New generation wiring harness
we have been getting our harnesses from agri-services for a little while now. they seem to make good harnesses and they come with a diagram and key for where everything should go. takes 2 to 3 weeks from when you call and order to when you will get it because he makes them as they are ordered, works out of his garage i believe.
http://www.wiringharnesses.com/
You may want to quote John Deere as well, the last time I checked, they where cheaper at John Deere by a lot. JD is making new generic harnesses that works on all side console tractors, at least for main and engine harness.
Here's the JD part numbers with prices.
AR43986 HARNESS WIRING INSTRUMENT PANEL ADD 96.66 USD
AR48937 HARNESS,WIRING,MAIN LIGHTING ADD 154.21 USD 154.21 USD
AR48936 HARNESS,WIRING,MAIN ADD 276.30 USD
AR50914HARNES,WIRING,ALTERNATOR TO MAIN ADD 408.87 USD
AR43609 HARNESS WIRING ADD 28.34 USD
*Total 964.38 USD
We made our own. We used the original for a pattern and bought crimp on ends and shrink wrap. We used one size bigger wire than Deere did. Total cost was less than $50. Tom
