Sarge Wilson
New User
I have a 1970 vintage 410B that worked great up until a few months ago. I have lost hydraulics to all functions except the transmission. I was driving it home when I lost steering at the end of my driveway. I found the fluid level low. After replacing fluid I manually turned in the destroke bleeder screw on top of the destroke valve and still had no hydraulics. I removed the destroke solenoid and tested the electro magnet it works fine but I'm not sure if it is suppose to open the small holes at the end of the solenoid. It doesn't seem to move anything. The manual states in the trouble shooting section that no hydraulics the destroke solenoid could be the fault. I have good flow through the pump. This is an expensive part and want to check with others before I purchase it. Any ideas would be appreciated. Thanks
