Jr,
I believe early styled will up to serial # 584,000. It seems to me if I remember correctly the unstyled and early styled are a two bolt housing while the later styled tractors are three bolts and will not fit. i also think the pedals are at a different angle and will not work. Good Luck, John
According to the manual, Brake Part # AA1079 (Main Casting) will fit Serial Number 424025 (1936 Model) thru Serial Number 583999 (Mid 1947 Model). All other models use different part numbers.
