The roosa injector pump on my 1972 820 3cyl diesel is leaking fuel at the bottom of the pump, when the tractor is running. I have a attached a
picture with a red arrow pointing to where the leak is. It looks like some sort of cap is missing. A short shaft is showing. The exposed shaft has
a small hole in it and there appears to be threads at the end of the shaft, which were only visible to me, when I looked at the photo on my computer
and zoomed it on that spot.
Can someone help me identify what if anything is missing or what might be causing the fuel leak here. I know this is where the fuel is leaking from.
Thanks in advance.
Thanks in advance.
