Randy K. Crump
On my 1951 JD A the #45 loader lifted over 900 pounds. I took the loader off, hooked the 11 foot disk with no weights on the hydraulic port on the right side in back of the tractor and it won't lift the disk. It will place it in the ground (wheels will move all the way up) but when I move the lever the other way it moves the tires to the ground and that is it. No shaking and the lever does not move back to the middle position. I have enough oil in it. Did I loose pressure when I placed the dummy rods in the back two port holes and used the side port holes for my disk? (I used the back two port holes for the loader, but I did not have the correct coupling to use the back two for the disk.)
