Depends on one's mechanical ability but cylinders are difficult to rebuild. External snap ring(key 13) needs to be removed then guide(key 8) driven into barrel to expose another snap ring(key 12). There's a serial break for parts from JD at 025301
Not too bad. I did one lift and both bucket cyl. on the 158. I had to hook the rod end back up in the tractor to hold it good enough to get the packing nut loose. They are to be on there TIGHT !
