marvel schebler carb
WORNOUT
my carb from a D is missing the ball and spring that stop the idle adjusting needle from moving when set. what can I do to repair this?? TYhanks
The ball and spring have been available from Deere in the past, can't say about now.
The SS ball is .156" diameter, Spring is slightly less and about ?" long.
It's tricky to install the spring and ball and get them staked to stay in, sometimes impossible, but can be installed behind needle and work ok.
Carb will have to be removed from tractor to make this repair.
Suggest sending to a shop capable of helping you with this, especially if it's time for reconditioning anyway.
MikeS.
