3020 early/late steering interchange
Joes Pizza
New User
I am rebuilding a 69 3020, powershift and need a steering column. The original is broke, F-11 loader front supports broke and took it out among other things. I have a 65 302/0 synchro range,will it interchange? Also will the hood, steering wheel, and air cleaner, I also either need a reservoir for the hydro cooler or can I use one I have from a 4020 powershift, it is a one piece.
im pretty sure the throttle stop notch is located differently on an early vs late.i think when you put a late valve on an early tractor you have to
build up the stop on the slow side to get it to stop before shutting down tractor. early valve to late tractor you may have to grind the notch wider
to let throttle go to idle not sure though.
(quoted from post at 10:28:11 04/18/17)
Steering valve & wheel should interchange but hood won't because early model has round muffler & late model has oval muffler.
I have the 65's muffler, the 69's got trashed by the loader.
Valve will work, steering wheel has a different dish.
Will fit but be uncomfortable.
Hood will fit so the older muffler will work. The older
cooler is probably too large.
