seems all i do with this tractor is move it out of the way. two days ago was running it and lucky i saw the flywheel nearly off the spline shaft.
I will check the tightness later because of a bum shoulder.
can someone point me to a write up about maintenance of the flywheel. fifteen years ago i replaced the cork oil slinger and after probably 10 hours of actual use it leaks again.
Is there a aftermarket flywheel that would be easier to work with. I could not get the right message to get google to work.
