I am working on a 4055 trying to trace out the charging circuit. I don't have a 55 series book or wiring diagram. What I've found is the connector at the alternator that has two wires, one is voltage sense (should be hot all the time) and the other should be hot with ignition on to turn on the regulator. This wire is also hot when the ignition is off, so it will slowly drains the batteries. I've traced it back to the connection at the dash, but past that I'm going in blind and I have no desire to hack at it.
Anyone run into this before or have a wiring diagram they could share?
Thanks,
Mike
Thanks,
Mike
