What would be the largest shredder that I could use on a 2240?
So far, I was using a heavy duty 10 ft Rhino but I had to replace the load control shaft, including the washer and o-ring. I bought the tractor used but I fear using the heavy shredder may have ruined the load control shaft and washer.
I have the user manual and the technical manual of the tractor, but could not find information on the size of the implements that could be used with the tractor.
Thank you,
Paul
Thank you,
Paul
