Mnethercutt
1010 battery ain't charging. Took the genny to a service place and it was tested and worked great. I've re-wired the whole tractor per the original wiring diagram. Still not charging. VR was new out of the box, but when I first hooked it up after polarizing I heard a pop when I tried to start the tractor. Took the cover off and checked the wiring, didnt see anything burnt or frayed. I've tried one of the guides on here, ground the field on the gen and the VR, bridging the bat and arm terminals, bridging the bat and field terminals. No real differenc.e Never seen charging get above 12.9 volts @ 1200 RPM. Any ideas? Is the genny supposed to have a ground wire?
Thanks.
Thanks.
