John Deere 4020 brakes
Todd1969
Have a 4020 brakes work fine while the engine is running. If you have the brake pedal pressed while you shut of the engine the brakes hold. But if engine stalls before you push the breaks the pedal bottoms out. checked the check valves in brake valve all looked OK. A 3020 that I know of you can use the brake a few times with the engine off.
Tim wouldn't Todd1969 have a high pressure leak to sump causing this also like the 3 point or svc leaking?
