Axle Shaft removal tool worked
I wanted to post that the wedge trick that the JD service manual speaks of calls for a steel wedge to be driven between the axle shaft cast nuts and some folks on here posted that a steel wedge can mess up those nuts. I had a hunch and used one of my Sthil tree cutting wedges made out of hard plastic and this did the trick on loosening the axle shaft from the bearing cups. See picture. Now I have another post on removing the seal....
