Tim S., 4020 Steering Wheel
2510Paul
On my 1971 4020 the shaft the steering wheel is attached to has about 1/4" to 3/8" axial play (up and down). Is this an issue?
Looking at the parts book it looks like this shaft is attached to yet another shaft with a sleeve and pin so I am thinking this is just normal.
Paul
THE snap ring and groove along with the washer under it get worn over time, you can remove the steer wheel and replace them without pulling the valve,I will give you the part numbers needed after bit.
