Any online manuals for a 1937 John Deere D?
Need a manual that shows front spoked wheels, & proper way of removing front wheel. It is probably straight forward, but would like to see it before beginning. Would be nice to have an online manual to refer to on other topics also.
have you checked the JD online parts manuals? I have a cd parts book for the old JDs that I bought years ago, if you can't come up with something let me know and I will see if I can email you a picture. I have a 1938G, what is your SN?
Take a look at the diagram below.
a156776.jpg" width="650"
Note the various hub caps (Key 11A - 11F), front wheel bearing nut (Key 10), outside and inside front wheel bearings (Key 2), front wheel retainer (Key 6), and felt washers (Key 5).
This was the process used for removing a spoke wheel from one of our Model B tractors.
Remove the hub cap.
a156778.jpg" width="650"
Loosen the cap screw and remove the front wheel bearing nut.
a156779.jpg" width="650"
Remove the outside front wheel bearing.
a156780.jpg" width="650"
Remove the spoke wheel.
a156781.jpg" width="650"
If necessary to inspect/replace inside front wheel bearing, remove the front wheel retainer.
a156782.jpg" width="650"
If necessary to inspect/replace felt washers, then remove the two felt washers.
a156783.jpg" width="650"
Hope this helps.
