rfridy76
Will a JD 50 starter bolt up on a late model B? I know its different voltage,my B is changed over to 12 volts.
I switched my B to 12v 35 years ago. Never did change the starter and no problems since. The B, 50 & 520 all use the same starter drive.
The 1107942 (B) and 1108144 & 1108155 (50 & 520) starters don't care if its 6 or 12v or + or - ground. Tough little starters.
