Deere Mike
Gentlemen, I finally found a m4600t front axle for my 420-W. They are hard to find and seem to brake or crack.
Before I install it, would it be better to weld a steel plate across the bottom to keep it from cracking in the future?
This piece is cast... and would the steel piece do anything to make it stronger or no help at all. I don't plan to the uses the front wheels extended out, so this may help.
Thank you for your help
Mike
Mike
