2020 clutch adj
bv
My 2020 grinds when engaging the pto but doesn't when changing transmission gears so you have to shut the engine off to engage pto, is there a adjustment on the clutch for this?
Does your tractor have a 2 stage foot clutch (Deere called it "continuous running PTO"), an independent hydraulic actuated PTO (lever between the two shift levers), or the standard (non-live) PTO?
don't know about the clutch but the shifter is located on the left benhind the clutch petal
The fact that your tractors pto control lever is by your left heel when sitting in the seat doesn't answer ss55's question because all three(3) pto types have same type shift lever
BV my 2020 has the two stage clutch they are referring to. When I depress my clutch lever all the way down I can feel approximately the last 2-4" get harder (second stage). I can then engage the pto with no grinding.
