Landon Becker
New User
I have a 1940 JD A that has a growl / grinding sound coming from the clutch only when it's engaged. I have replaced the bearing and sleeve bushing on the clutch pulley, and all the bearings on the primary and secondary shafts. All the gears seem to be in good shape inside the trans. Is there something in the adjusting of the clutch itself or the clutch plate that would make this noise? I haven't replaced any clutch parts other then the bearing and sleeve bushing. I do notice when the clutch is engaged that it will move in and out some.... The noise will come if it's in gear or parked. It gets much worse when it warms up.
Thank you all for a helpful site!
