Which 4020 oil pan casting # is correct for a 72?
I have a 72 4020 with the newest block ( block heater hole and mounting for ac compressor) that I am working on restoring. Which oil pan casting number is correct for this tractor? R44419 or R53741?
Thank you!
I had one here but sold it.The 12quart is the correct one and was also on the 4000s 69/72.The 64/68 all had the 8 quart pan.The 4320 had a different one due to oil filter but same capacity.The 12 quart pans are a harder to find and bring around $400 the 8 quarts are plentiful and don't have much value.
