1969 John Deere 112
Alex Duncan
New User
I am currently restoring a 69 John Deere 112 the serial is 131599M and the type is TO656. I have ran into an issue with my local John Deere store they can't find the right belts. Does anyone happen to have the correct numbers for the primary, secondary and the hydraulic belt?[/img]
Go to jdparts.com. Lookup 112, belts are listed. Hyd is with the pump. Go to another JD dealerorfinda partsman that knows how to look up parts.
(quoted from post at 01:26:39 04/04/17) I am currently restoring a 69 John Deere 112 the serial is 131599M and the type is TO656. I have ran into an issue with my local John Deere store they can't find the right belts. Does anyone happen to have the correct numbers for the primary, secondary and the hydraulic belt?[/img]
Part Numbers Below
M44121 BELT
M82258 BELT
JDPARTS.COM
its all there!
(quoted from post at 18:28:58 04/03/17)
Part Numbers Below
M44121 BELT
M82258 BELT
JDPARTS.COM
its all there!
Awesome thank you guys for your help
Looks like you are in the models from ser# 250000 and up. This fellows is below that at 131599 and may be different.
They are the same M44121 secondary and M82258 primary on the 131599 ser#
Hyd pump belt depends on Kohler engine # M44113 with 90* pump, or Tecumseh engine # M43106 with in line pump.
