I have a hydraulic fluid leak at what I "Think" is labelled as the hydraulic oil return line (AR71319 ??) The leak is at a fitting on the right side where this line goes to an elbow and then there is a nut that is in the rockshaft housing (?). It appears beneath the nut there is an aluminium washer.
On the tractor with the leak the line has been replaced with a hydraulic hose. I have attached 2 pictures:
1) The fitting where there is a leak
2) A picture of the line on another tractor which I think is the original part.
Questions:
I cannot find the parts diagram that shows the nut/fitting in the housing. On the tractor it is very tight and just checking if there is something else I should know before forcing it a bit.
There is a similar line on the left side...I may not be at the right diagram but did not find a left and right hydraulic line.Would like to replace the existing hydraulic hose with the proper metal pipe.
Thanks for any help!
Rich
Questions:
Rich
