Just want to be sure, but does anyone know on a 2013 JD 6105D, when the exhaust cleaning light comes on telling you the exhaust is hot enough to clean, can you continue to run normally? The tractor speeds up to 1250 rpm I believe and won't go below that, but can you go ahead and run it full speed?
Also, does it get hot enough say baling prairie hay to worry about setting the grass on fire if it is cleaning when you are baling? Anyone have much time with the setup? Thanks in advance - Bob
