Dieselcowboy
Just got this L recently. I've noticed 2 things about it. First the clutch doesn't want to disengage very easy. I have it adjusted right but when
going into gear I have to nudge a gear to get it to stop. Or after driving it awhile and push in to stop it won't, having to hit the brakes pretty hard
to disengage the drive. Any ideas ?
Second the drive shaft seems to be out of round causing a vibration in the trans. Can watch it from the bottom side and see it clearly. It has a
rubber mount on one end. Is it possible that has been replaced and holes not drilled correctly causing what I described?
Any help is appreciated
