MaverickM23
Working on my 4430 had the front hydraulic pump out to replace o rings on the fittings, got it started and set the stand by pressure to 2250, checked it on the remote. Used the three point hitch and it raised all
the way up. But when I go to lower it the hitch will not stop at any position except all the way down. Its like it is either all the way up or all the way down, no in between. Is there adjustments that I can do to fix
this? Thanks
this? Thanks
