4240, L35843
dwag
Replacing a leaking T22958 oil cooler return hose on a 4240 which subs to L35843. Darn thing is impossible to install and ruined by stretching w/snap ring pliers. What to do? Thinking heat gun? This is the L shaped hose under left front floorboard.
L35843 Inside Diameter (Large) 0.748 IN Quad Range
TY22425 Inside Diameter (Large) 0.750 IN Power shift
Quad. Old hose just rubber and would be easy to replace, new sub# hose very stiff with a hard plastic type inside liner.
Sounds like you have the wrong hose,they go on easy..and like Tom said the new one will need cut to fit,save the end you cut off it will work in other places
Hose I now have would not need to be trimmed IF it would go on, hope the one I re-order is right. Thanks all for reply's
