I'm trying to flow test a 2950. I have my inlet plugged into the pressure line off the pump before the pressure control valve. My outlet is plugged into the right scv, right port with the scv lever tied back. I'm only getting about 5 gpm and not steady. That cant be right can it? I had 2200 psi at the scv with my gage plugged into it. Reason for flow testing- draft goes up slowly, pump is a little noisy, and the loader will raise slowly and hop. I installed a new filter, and cleaned the pump screen. I checked stroke control valve and the seat is a little worn but not to bad. What am I missing?
