Got it split to fix the pto because the stub shaft came loose. Done.
Removed rockshaft housing & took the rockshaft valve apart to check/clean/ replace whatever needs it. 1 spring & ball missing. It's getting all new o rings also.
Removed trans pump & pipes. Gears scored, o rings missing, & check valve seat/bushing was installed upside down.
Rebuilt the brake valve. Lots of silicone pieces in it.
Filter relief valve is off but I haven't taken it apart yet.
Load shaft is removed to replace bushings & seals with the o ring style. Also replacing front drawbar bushing & pin.
Steering valve is at Tim S' to be checked out.
I'll flush the housing & can start reassembly. Then the final drives come off for new brakes & whatever else I find in there. Every seam on this 4010 has blue silicone on it. Somebody's
been into it before.
