Hey guys. Tearing into my first two cylinder and have a few questions. I'm dropping the head off at the machine shop today for a valve job.
Where is a good source for the gaskets I will need?
I have read about lead washers being used on the head studs. There were no washers when I took mine apart. Should there have been?
How should I prep the head gasket when replacing it? Anything I should be applying to it?
I'm looking for a couple parts for the cooling fan. D396R friction disc and D3263R key, and D399R friction washer (2). I'm sure I could source the keyway locally if I cannot find one. The D396R spun on the shaft and wore down the key.
Thanks in advance for any advice.
MJ
MJ
