Picked up a 2440 in the fall and I am finally getting it ready to be put to work this spring. The 3 point shutters on the way up and I checked the pressure at the rear remotes, it didn't get over 20 PSI. If I put the fitting before the PCV on the pressure line it will read 2400psi. I swapped the PCV with one off of my 1020 and no change. I may swap the Rear valves between the two tractors and see if that narrows it down.
My IT manual says it is in the pump, but pressure seems good off of the pump and the tractor steers fine. Any tips. (I know the IT manual isn't worth much in this case)...
